hORNS FP6
Price per Pair
Versatile and flexible
The Horns FP6 is a very high performance option for users of compact audiophile stand monitors. The FP6 has the prized advantages of a very low distortion, high-dynamic treble system with a cabinet platform to match. Horns and compression drivers originate in prosound, which means the FP6 has the clarity, dynamic poise, and definition to power a unique theater experience.
Compact and sophisticated
The Horns FP6 stand monitor with SEOS has something not usually found in the audiophile's compact precision stand monitor: The sophisticated sound possible only from a horn treble driver. Experienced audiophiles know the compression treble driver and excellent horn design can create a degree of dynamic poise, nuance, and simple acoustical "rightness" just not found in a conventional speaker.
The imported Horns FP6, by Poland's AutoTech, has just such a treble system. Driven by a premium-grade 1" compression driver, the SEOS horn
is molded from cast, polished acoustical concrete and designed for precise dispersion and ultra-low distortion. The FP6's entire front baffle is finely crafted from this advanced, low-resonance material, making the FP6 loudspeaker as exacting as it is unusual.
Quality throughout
The Horns FP6 is top-drawer throughout. The alloy-framed, poly-coned 5.5" midwoofer is tuned to a heavy-weight, highly damped, furniture cabinet. Audiophile-style input terminals feed a high performance crossover made from top grade components.
- Enclosure volume - 13L
- Sensitivity - 87 dB
- Frequency Range - 50-20000 Hz
- Impedance - 8 Ohm
- Cabinet dimensions - 214x309x320 [mm]
- Stand dimensions - 265x720x390 [mm]
- Weight, Speaker - 10 kg
- Weight, Stand - 12 kg
- Includes black steel speaker stands
- Truck delivery in the 48 continental US states
- Natural bamboo only
- 2-way
- SEOS cast horn
- Bass reflex
- 2nd order crossover
- Cast acoustical resin baffle
